Skip to content
    May 6, 2025
    Stop Treating SAP Like an Island: Why True Business Automation is Ecosystem Wide
    6 min read
    Key Takeaways
    • Discover how end-to-end business processes extend beyond SAP, and flow across CRM platforms, cloud storage, ITSM tools, and more.
    • Leverage Automic Automation to establish true end-to-end visibility, control, and automation across the entire hybrid IT landscape.
    • Connect all components that make up critical business processes, enabling improved agility and resilience.
    SAP is undeniably the backbone of many critical operations. Whether it's SAP ECC, S/4HANA suite or RISE with SAP - SAP applications often house the core logic for finance, logistics, manufacturing, and more. But here's a crucial question: Do the business processes that rely on SAP data and transactions begin and end neatly within the SAP application itself?
    For almost every organization in my experience, the answer is a resounding “No.” Yet, many persist in managing SAP automation in isolation, treating it like an island disconnected from the broader IT ecosystem, using files and time as a way to “connect”. This approach creates blind spots, fosters inefficiency, and introduces fragility into the processes you rely on most.
    The reality: Your business processes swim in an ecosystem
    Consider common, critical end-to-end processes:
    • Order-to-cash workflows: An order might originate in a CRM (like Salesforce), trigger inventory checks and fulfilment logic in SAP (whether S/4HANA or ECC), update shipping information via a third-party logistics portal, store data in cloud buckets (such as AWS S3 or Azure Blob), generate invoices back in SAP, and finally update reporting dashboards on a separate analytics platform (like Tableau or Power BI).
    • Procure-to-pay processes: A request might start in a business user’s Service Catalog (like ServiceNow) or a third-party procurement platform, require approvals, generate a purchase order in SAP, involve business-to-business communication with suppliers via EDI gateways, track goods receipt in SAP, process invoices using an OCR/scanning tool, and trigger payments from SAP, potentially interacting with treasury management systems.
    • Supply chain operations: Demand signals from external forecasting tools might feed into SAP Integrated Business Planning (IBP), trigger production orders in S/4HANA, coordinate with warehouse management systems (WMS), interact with manufacturing execution systems (MES), and push data to cloud-based analytics platforms for performance tracking.
    SAP is vital in each case, but it's just one node in a more significant, interconnected flow. Relying solely on SAP-specific schedulers or building brittle point-to-point integrations between these components leads to significant problems:
    • Lack of end-to-end visibility: When a process stalls, where's the bottleneck? Is it the SAP job, the file transfer to cloud storage, the API call to the CRM, or the legacy mainframe? Siloed tools provide fragmented views, making troubleshooting slow and painful.
    • Process fragility: Simple point integrations often lack sophisticated error handling and dependency management. A failure in one system can have cascading, unpredictable impacts across the entire chain, making manual interventions frequent necessities.
    • Operational inefficiency: Manual handoffs between automated segments, delays caused by polling for files or events, and the inability to optimize the entire workflow result in longer processing times and increased operational costs.
    • Increased complexity and maintenance: Managing dozens of disparate scripts, scheduling tools, and custom integrations requires specialized skills and significant effort, diverting resources from innovation.
    The solution: Unified orchestration across your entire hybrid landscape
    To fully master your business processes, you must manage automation from an ecosystem-wide or business flow perspective. Automic Automation from Broadcom is architected precisely to meet this demand. It provides a single, unified platform to orchestrate workflows across your entire hybrid IT landscape—including SAP and non-SAP, on-premises, and multi-cloud environments.
    Automic Automation is available as a customer-managed solution (for on-premises or cloud deployment) and as a SaaS offering (Automic SaaS). With its advanced, AI-powered capabilities, Automic breaks down silos, enabling you to achieve these objectives:
    Orchestrate truly end-to-end processes
    Visually design, execute, and monitor business processes that span these environments:
    • All versions of SAP, including S/4HANA, RISE with SAP, and Business Technology Platform (BTP) services.
    • Non-SAP systems like CRMs, cloud platforms (including AWS, Azure, and GCP services), data pipelines (such as ETL tools and Databricks), ITSM platforms, mainframes, and more are accessible via an Automation Marketplace.
    Gain complete visibility and control
    Get a single-pane-of-glass view of your entire automated process, regardless of the underlying technologies. Understand visible and invisible dependencies, track real-time progress, and quickly pinpoint issues, whether they occur inside or outside SAP.
    Leverage an extensive integration ecosystem
    Connect seamlessly to virtually any application or infrastructure component. Utilize certified SAP integrations, tap into hundreds of pre-built integrations via the Automic Marketplace, or leverage robust APIs for custom connections.
    Implement event-driven automation
    Trigger complex, cross-system workflows based on real-time business events—a file arrival in cloud storage, an API call from a web application, a message bus event, or an alert from a monitoring tool—not just calendar, time-based schedules or SAP event based within SAP.
    Add proactive resilience with Automation Analytics & Intelligence (AAI)
    Automic's integrated AAI capabilities provide predictive analytics and operational intelligence across the entire orchestrated workflow. Dynamically predict potential SLA breaches for the end-to-end business process, not just individual SAP tasks and maybe even more importantly understand when you are “back on track”. Accelerate root cause analysis, no matter where the failure occurs in the chain.
    Automic: Enterprise orchestration with deep SAP DNA
    Automic isn't just an external tool bolted onto SAP. Automic offers deep integration based on our proven expertise in managing the complexities of SAP environments. Our certifications demonstrate this expertise for S/4HANA, RISE with SAP, and NetWeaver. However, unlike tools focused primarily on the SAP world, Automic provides the enterprise-wide breadth necessary to manage the complete business processes that drive your organization from Mainframe and distributed, over microservices to native cloud and SaaS applications. Available as a customer-managed and SaaS offering, the solution delivers the scalability and reliability needed to handle complex, high-volume workloads across your entire heterogeneous estate.
    Stop managing islands, start automating ecosystems
    Treating SAP automation as an isolated island guarantees inefficiency and risk in a world where business processes are deeply interconnected. Embrace a unified orchestration strategy that mirrors your actual operational reality.
    By leveraging Automic Automation, you can move beyond basic SAP job scheduling to achieve true end-to-end business process automation, gaining the visibility, control, resilience, and agility needed to thrive.
    Ready to seamlessly connect SAP scheduling into truly integrated, end-to-end process automation?
    Explore how Intelligent Orchestration for SAP can accelerate your enterprise-wide automation journey.
    Dave Kellermanns
    Dave Kellermanns is a Global Advisor for Workload at Broadcom. In the past he has worked with a variety of Fortune 100 companies to review and strategize around their automation strategy and start innovating for the benefit of the business. As companies need to automate at a rapid pace in order to innovate, in his...
    Other posts you might be interested in
    Explore the Catalog
    icon
    Blog July 9, 2025
    Enhance Your Expertise: A Comprehensive Guide to Our Free AutoSys Training
    Read More
    icon
    Blog July 9, 2025
    Master Automic Automation: Your On-Demand Training Journey Starts Now
    Read More
    icon
    Blog July 9, 2025
    From Insight to Foresight: Advancing Your Strategy with Automation Analytics & Intelligence Training
    Read More
    icon
    Blog June 23, 2025
    Democratizing Automation With the AI-Powered Filter Assistant and Seamless Python Scripting
    Read More
    icon
    Blog June 19, 2025
    Simplifying Data Transformation: How Automic Automation Powers Dynamic Data Pipelines and Business Agility
    Read More
    icon
    Blog June 6, 2025
    Large Regional Bank Experiences Impressive Growth in Automic Automation Usage Over Four Years
    Read More
    icon
    Blog May 22, 2025
    Maintaining a Clean Core in SAP S/4HANA While Promoting Cross-Ecosystem Orchestration
    Read More
    icon
    Blog May 20, 2025
    Predictive Analytics: Gaining Certainty for Mission-Critical SAP SLAs
    Read More
    icon
    Blog May 15, 2025
    Building a Self-Service AI Agent With the Power of ASK_AI in Automic Automation V24.4
    Read More
