Skip to content
    June 22, 2021
    What Kind of Certificates Should I Use for Automic Automation v21?
    Key Takeaways
    • Select appropriate certificates for secure communication, enhancing the safety of your automation processes.
    • Utilize trusted certificate authorities to ensure the validity and reliability of your security certificates.
    • Monitor certificate expiration dates to proactively manage renewals and prevent service disruptions.
    The next version of Automic Automation mandates TLS/SSL for communications between the engines, Automic Web Interface (AWI), and most agents. Customers have to decide what type of certificates they will use to secure the communications across Automic.
    A public-key certificate contains information like name, hostname/domain name/IP address, validity period, the location that can be used to identify the owner (server), and the public key that the client uses to verify the server. By signing the certificate with a digital signature, for example, Public Certificate Authority (CA), you can ensure that the certificate is valid and trusted by all clients who trust this CA.
    The Automic Automation TLS/SSL implementation uses public-key certificates in X.509 format and TLS version 1.2 for secure connections between the server and AWI/agents.
    There are several questions that customers need to ask before moving to Automic Automation v21:
    • Does your company already use certificates signed by a third-party CA, and can they also be used for Automic?
    • Do you need to comply with strict security standards when using Automic Automation, especially in production environments?
    • Who is going to be responsible for managing the certificates? Is there a dedicated person/team for the Public Key Infrastructure (PKI) in the company?
    • Who will be responsible for installing/distributing certificates and configuring TLS/SSL for Automic Automation?
    • How many certificates will you need? Is it just a couple for your Automic servers, or do you have to manage multiple servers spread across many locations and need to have a centralized view?
    • How important is connection security? What’s the worst that could happen if a certificate is expired or is compromised?
    Based on your company’s requirements and resources, three main types of TLS/SSL certificates are available to secure communications.
    Certificates Signed by a Public Certificate Authority
    The main benefit of using certificates signed by a Public CA (DigiCert, Microsoft, Let’s Encrypt, ...) is that they are usually already trusted by many operating systems or applications, thus eliminating the effort of deploying them to all clients.
    The root certificates of these authorities, or intermediate ones signed by the root CA, are often installed as trusted certificates in the Windows certmgr, Unix OpenSSL truststore, or the Java trusted Keystore cacerts.
    A CSR (Certificate Signing Request) must be created and sent to the responsible authority to have certificates signed by a CA. Typically IT departments take care of CSRs, and public CAs offer APIs to send CSRs.
    Commercial CA certificate renewal can be done either by using vendor-specific tools or via their website.
    Certificates Signed by an Internal Certificate Authority
    For testing purposes or applications that are not Internet-facing, another alternative uses the benefits of having CA-signed certificates without turning to third-party vendors - creating your own Certificate Authority.
    The root certificate of the internal CA can then be used to sign certificates for hostnames and domains within the company. A CSR request is required to sign other certificates with this CA.
    Certificates signed by an internal CA can be renewed by re-using the previous private key/CSR to create a new server certificate.
    Self-Signed Certificates
    While using self-signed certificates gives you the flexibility to manage your security without being a TLS expert, renewing and distributing them is your responsibility.
    There are plenty of free tools to generate self-signed certificates, like Java’s keytool, openssl, or via the UI of KeyStore Explorer. To renew self-signed certificates, you will need to replace the old certificates with new ones.
    What To Do Next
    The decision of which kind of certificates to use for your Automic systems should be carefully considered, as it determines not only how secure the connections will be but also influence the amount of time you need to invest in renewing and deploying the certificates.
    Sometimes, a combination of the above might be the best way to go, depending on your security needs and knowledge of TLS/SSL.
    We have created a series of guides to walk you through the creation and deployment of certificates across a new Automic Automation v21 installation:
    Oana Botez
    Oana is a Product Owner at Broadcom with responsibility for the Automic Automation product and has a background in Software Engineering. Her current focus is on improving security by implementing modern standards like TLS/SSL and on delivering the first container-based solution of Automic.
    Other resources you might be interested in
    icon
    Blog November 24, 2026
    How to Send AppNeta Network Alerts to Google Chat with Gemini AI Summaries
    Learn how to send AppNeta alerts to Google Chat and have them enriched with AI-powered root cause analysis and triage steps from Gemini.
    icon
    Office Hours November 19, 2026
    Rally Office Hours: November 19, 2026
    Get the latest product updates, including new help URLs, a new test case coverage widget, and pie chart widget enhancements. Find out about Rally events.
    icon
    Blog November 18, 2026
    AutoSys Receives SAP Certification for SAP S/4HANA Cloud
    AutoSys Workload Automation is now SAP-certified for SAP S/4HANA Cloud. See how you can unify orchestration across your modern SAP and cloud ecosystem.
    icon
    Blog November 13, 2026
    Advancing Workload Automation Security with Frontier AI
    Frontier AI has fundamentally changed the security landscape. Find out how Broadcom leverages frontier AI to harden its workload automation software.
    icon
    Course November 12, 2026
    DX NetOps: Network Observability Deployment Engine (NODE) Install
    Learn how to establish the foundational architecture for the Network Observability Deployment Engine (NODE) by mastering the deployment of CaaS and LCM.
    icon
    AppNeta: Manage Organizations and Users
    Learn how to configure and manage core AppNeta organization settings, create child organizations, and provision user accounts.
    icon
    Office Hours November 12, 2026
    Rally Office Hours: November 12, 2026
    Watch a demonstration of the Rally MCP server running with Claude. See how an automated workflow can generate release notes from a Rally milestone.
    icon
    Office Hours November 5, 2026
    Rally Office Hours: November 5, 2026
    Explore the new time in state widget, including configuration options, supported artifacts, and upcoming features. Hear about upcoming Rally events.
    icon
    Course October 30, 2026
    Automic Automation V26 Administration Foundations
    This course takes you from a baseline engine installation to a fully secured, intelligent, and production-ready automation landscape.
